I got an everlasting problem with a aerated autoclaved concrete (also known as "Gasbeton") wall: there's a crack that seems to split the upper half from the bottom half of the wall.
I tried several time to fix it, either with the proper aerated autoclaved concrete putty and with stucco but, after some days, the crack comes back again.
Any idea on how to fix it for good?
EDIT: The wall is made of AAC blocks (as bricks), I have access to both sides and is an interior wall: basically it divides one former big room in two smaller rooms (kitchen and bedroom).
dag729
  • 121
Instead of trying to fix the crack, first try figuring out what is causing the crack. You can fix a crack many times, but if you are fighting against something like water pressure (or one of the many other causes of cracks in concrete), you will never win. Once you find what is causing the crack, then look to mitigate the problem somehow (proper drainage in the case of water buildup), and then fixing it one final time will take care of the problem.
Jeff Widmer
  • 8,252
  • 49
  • 65
