  1. I'd like to heat my pond to create a hole in the ice during the winter to help a few goldfish survive. The fish are not expensive but I'm trying to save them. The pond is about 50 gallons, about 12 inches deep at the most. Pond is a commercial stiff liner that is kidney-shaped.
  2. I've seen the pond heaters use a lot of energy, 1500 watts or more.
  3. I have an aquarium heater and I might try that but those can be 1000 watts or more. But I'm concerned it will not survive a 100% duty cycle in mid winter.
  4. I'll be using 120vac to heat the pond. Glow plugs seem to all use 12vdc so that's not a great option but I can convert 120vac to 12vdc.
Is there a more efficient way to turn electricity into heat to just keep an open hole in the ice in the pond? I am familiar with basic electronics and make LED lights as a hobby.
Thank you.
Bulrush
  • 316
The only way to be "more efficient" than a resistive heater is to use a heat pump, and the upfront cost will probably make that a non-starter. Resistive heat is 100% efficient, a heat pump can be 300% efficient. Either way, you are fighting the weather and it takes a lot of energy.
Getting a big horse watering trough (or, given the size of your pond, a small watering trough, or an actual aquarium) and moving the fish into the basement (or perhaps living room, etc. with the aquarium option) for the winter will be far less costly than melting ice all winter.
Instead of using heat and letting it all escape you can use a insulated dome to provide a non-iced over spot.
ratchet freak
  • 14,551
  • 42
Moving water doesn't freeze unless it's extremely cold. Perhaps a small fountain or bubbler in the middle of the pond would keep it open.
Jim
