Circuit breakers have to be attached to both sides of the electric panel in such a way that it balances the load. I would like to know if:
  1. I should ensure left circuit breakers Amp is almost same as right panel breakers.
  2. Should I balance based on usage? e.g., refrigerators are always working but ACs do not work in winters.
  3. Do 2 pole breakers have to be evenly distributed as well?
Any ideas on the right way to arrange the breakers?
  • 139,495
  • 149
  • 386
marc Katz
  • 109
What matters is your actual draw, not the numbers on the breakers.
So for instance, if you have 5 circuits of bathroom, bedroom, laundry room, and kitchen... And then 5 circuits of Bitcoin miner that run at 15.9A 24x7... You don't want to put the miners on one leg and the household load on the other. The 2 kitchen circuits are rarely used, for instance, so they don't balance the miners.
On the other hand, if you have a gaming rig circuit and an air conditioner circuit to keep the room bearable, thatd be a pretty good balance since they'd run together.
It isn't left and right, unless it's PushMatic
Most modern panels arrange like this.
