I have a toilet that makes a gurgling noise IF it flushes down. However, at times it will fill up when I flush the toilet and I will see something come up from the bathroom drain. I have tried putting septic tank cleanser through the toilet because I have a septic tank.
What should I do to find and fix the problem?
  • 20,909
  • 95
  • 135
You have a blockage that is in the main pipe downstream of where toilet and the bathroom drain collect, so it is backing up both of them. Since the chemicals are not doing it, it looks like it has to be augered.
Kaz
  • 850
