I'm installing a handrail for a short flight of stairs at the bottom of an interior staircase which is adjacent to a solid concrete block wall.
The options I've been considering for fixing the handrail brackets to the wall include countersunk sleeve anchors and concrete screws.
I was thinking sleeve anchors would be more secure but there's only a very limited range of sleeve anchor sizes with the smallest being 6mm so I'm not sure if I would be able to find a handrail bracket with screw holes to match.
Another potential problem with using sleeve anchors is that they have to be spaced a minimum distance apart although there are handrail brackets with a single screw hole.
jrcollins
  • 45
I'd go with hex head tap cons. Pre drill the holes. If you are really worried then get some epoxy and put this into the hole before fastening - this is how rebar is inserted after the fact in structural applications.
If you want it to look perfect then probably choose whatever fastener look bests based on the bracket and drill a hole smaller than the fastener, ensure you blow the dust out of it and put structural epoxy into the hole. For ~$150 you can get the two part caulk gun and the epoxy. Something like this :
https://www.dhcsupplies.com/store/p/2464-SET-XP-22oz-Epoxy-Tie-Adhesive-with-Nozzle.html https://www.dhcsupplies.com/store/p/468-EDT22S-22oz-Manual-Epoxy-Dispensing-Tool.html
Fresh Codemonger
  • 14,459
  • 57
After a lot of searching online I finally found the perfect solution: https://www.homedepot.com/p/EZ-Handrail-1-9-in-Aluminum-Round-ADA-Handrail-White-Wall-Bracket-EZA200-W/202988226
The brackets are even white to match the wall I'm mounting them on!
The correct size masonry fasteners are also available from Home Depot: https://www.homedepot.com/p/EZ-Handrail-3-in-White-Masonry-Fastener-2-Pack-EZAT225-W/205846058
jrcollins
  • 45
