When I purchased my house the builder flipped the stairs and grilling deck. I can’t figure a way to fix the grade issue at the bottom of the stairs and along the back wall. The steps lead to an approximate 3’ x 3’ cement pad butted up to my foundation, which carries on to a cement walkway.
The problem is that the ground is graded on a slight downslope where water temporarily pools during rain. The issue is my septic tank comes out of the wall a few feet away. I can’t downslope the ground away from cement pad because my septic tank is too high. If I try to raise the cement pad it will affect walking down the deck stairs(only 4 steps) and also become higher than the walk. I am getting water droplets under a large portion of my crawl space vapor barrier.
I believe the water intrusion is because of the grade issue. Any advice will be greatly appreciated. Thank you
Joe
0 Answers0
