I am installing the following items:
and I am using regular 1 1/4" drywall screws to secure them.
Is there any concern in regards to shear strength or rot that would make me regret using drywall screws?
I am fully aware of the adage "Drywall screws are for drywall; it's in their name." but it seems like they are more than sufficient for my application. Especially with the single-gang box because the head will lay flatter making sheetrock easier.
Machavity
  • 26,498
  • 44
  • 100
MonkeyZeus
  • 17,328
  • 64
6 Answers6
I used drywall screws in the past for electrical boxes and stopped using them when I found that they snap off too easy when using a powered driver to insert the screws. They can also snap if there is any reason that the electrical box can flex. This is all due to the hard tempered nature of drywall screws.
Now I use #8 or #10 pan head stainless steel screws. If possible, when using the #10 size, I will even drill a pilot hole for the screw.
Michael Karas
  • 67,833
  • 68
  • 153
I use drywall screws all the time & have never been called on it during an inspection (would not use them for a ceiling fan box ). Some of those boxes only require the metal tabs be set with a hammer. I usually add a screw on those also.
Ed Beal
  • 103,727
  • 79
  • 158
Drywall screws are black phosphorus. They have absolutely no rust protection and are code required to be completely encapsulated in mud or wood to prevent future rust. In California they are fully against code to use for anything other then drywall. Gold screws are fine. A small step up in price, but with some rust protection.
Dan F
I use sheet rock screws for metal studs fine thread. They never shear off. Also I've never ever seen a child or adult rip a blue box out of a wall lol. Also also those metal tabs are not for permanent mounting of any box. They must be either nailed or screwed fast to studs. I would laugh any contractor off the job if they were only using the temp setting tabs on box for mounting.
If your electric boxes need water/rust preventive screws... I think you have a much bigger problem than black drywall screw fastenersjust my 2 cents ;)
-1
This is the way I see it, I am a flooring installer by trade and I always use premium products that I know I can rely on. I follow the manufacturer's installation procedure and I charge the customer for that. I charge more than most installers out there but you get what you pay for if your lucky. With how much an electrician will charge a customer you are nothing more than a hack if you use inferior supplies and charge a professional wage. That gang box will not last very long if it's in a young boys room who always runs into their room and slaps the switch. That's because the screws are cheap that's why you get so many for such a low price. If I ever had a electrician who used one sheetrock screw in my house, he wouldn't have time to use a second screw.
