I am installing laminate flooring in an area that has two bedrooms and a living area. The bedrooms are about 150 sq ft each and the living space is around 250 sq ft.
|    Bd #1    | stairs |                           |
|             |--------|      Living Space         |
|    Bd #2    |  Bath    |      Utility Room       |
I know about the standard spacing that must be left between the flooring and the walls. I also understand I should run flooring parallel with the longest wall. I would like to know if I should just run the entire flooring from room to room, or if I should separate it based on the rooms and have T moulding to transition from the bedrooms to the living space. I think this would help with the expansion of the flooring and be less likely to have bowing. I think it would look better to have no spacing at all, so maybe I'm being paranoid about the spacing/bowing. Is there a standard for this type of transition? I think once you reach a certain square footage you need to insert a gap, but I'm not sure what that is. Any advice is appreciated.
SwDevMan81
  • 461
5 Answers5
I think you should be more concerned with the expansion gap than other types of expansion.
In my opinion you should use some kind of separation between the living room and the bedrooms, because bigger rooms require bigger expansion gaps. And that difference in expansion could give some bowing.
  • 20,909
  • 95
  • 135
Javier
  • 114
Since each room in your house will have different temp and humidity levels, the T moulding allows each room to contract, expand, and flex independently of the others. This helps prevent warping and cracking.
user11139
As an installer, I have done many jobs where my client just didn't want a T-mold in the door ways. When I first started installing laminate, all the sides were glued together. This is where we always used T-molds.
Cutting Door Jambs 1These days they sell 10, 12 and 14mm thick laminate. These thicker products from what I have seen do not seem to grow or shrink like a 7 or 8mm.
All the buckling repairs I have done always involved 7 or 8mm. The one thing that I always pay particular attention to is under cutting the door jambs and maintaining the gap around all the walls.
When under cutting the jambs just make sure that you have the gap underneath where you can't actually see.
I have done many jobs without T-molds knowing that all the potential problem areas are OK.
Ant
It also depends what time of the year it is. In the summer when humidity is at its highest, the gap should be smaller as compared to a winter install.
  • 20,909
  • 95
  • 135
Smart
Depending on what type of laminate you bought, it may be difficult to transition from room to room without using moulding because I would think that you may start having to go backwards with the laminate??
Ken
