I was recently working on some wiring in my bathroom, and I noticed a 3rd load wire that I couldn't quite explain.
There were 4 Black Wires coming in (with 4 corresponding White Neutral wires). One of the Black wires was for the light, one was for the fan, one was the source (hot) wire, and there was a 4th one that I couldn't figure out.
What was really weird, is that the 4th wire seemed to be hooked directly to the source/hot wire. The entire setup was like this:
Switch 1 toggled fan
Switch 2 toggled light
Black/Hot/Middle -------> Top of switch 1 via Screw (middle of the wire was stripped, wrapped around screw and continued to switch 2)
Black/Mystery/End ------> Top of switch 1 via Insert
Black/Fan/End ----------> Bottom of switch 1 via Insert
Black/Hot/End ----------> Top of switch 2 via Insert
Black/Light/End --------> Bottom of switch 2 via Insert
If that list doesn't make sense, I can try and make a better diagram. Really I'm just trying to figure out what that last black wire was for, and why it was directly wired to the source line.
Thanks for any help/advice!
Tennesseej
  • 163
This is an onward feed to some other stuff somewhere else in the house
While in the US, bathroom receptacles need to be on a dedicated bathroom receptacle circuit (that can feed any number of bathrooms), with the exception that you can feed both receptacles and lights for a bathroom off a circuit that services only that bathroom, there is no such requirement generally for bathroom lighting. In other words, once the dedicated bathroom receptacle circuit is provided, the bathroom lights can be on a general lighting branch circuit. So, you'll want to put that "mystery" wire back with the incoming always-hot feed, lest you wind up inadvertently disabling some lights or outlets somewhere else in the house.
ThreePhaseEel
  • 87,685
  • 144
  • 243
I had a similar experience except it wasn the bathroom and they used the stab in connection and wire nuts. I discoveted ias t was already suggested to you, it was feeding an outlet on the same wall.
user116527
