We live in a condo and when the neighbors turn on their water is like the flood gates of hell. Is there anything I can do to block the sound.
Asked
Active
Viewed 762 times
Small diameter pipes can be noisy, but fitting larger pipes while the « solution » now can be difficult and expensive.
Usually happens when a small pipe feed an area which then has a change of use and the water demand increases which increases the speed in the small pipe.
Usually on domestic pipes the speed should be kept below 2 m/s while hydraulic systems can be up to 7m/s.
Solar Mike
- 30,038
- 2
- 34
- 69
