I have an old washing machine from the 90s, likely to be ~25 years old (make and model: Zoppas Pratica PTX43).
The machine has been working fine up to about two months ago. More recently, however, I noticed that every wash cycle seems to be taking longer and longer.
The average wash cycle duration used to be 2 hours, now it exceed 3+ hours and seems on the increase.
None of the searches attempted such as this or this yielded helpful results.
Most of the queries in the search seem to be about recently purchased machines or suggest problems that likely do not apply to my situation.
Symptoms
  • Cycles get stuck at intermediate areas (between one letter and the other, or at the start of one letter)
  • Machine emits a humming noise for the duration of the 'stuck' phase
  • If left unmanaged, this situation can go on for 30+ minutes
What I checked
  • Ensured that the washing machine filter is clean
  • Checked that both water intake and waste pipes are not bent
  • I don't believe water intake is not getting water as the clothes are being washed
  • Similarly the water is being drained so I do not believe the waste pipe is clogged
  • The soap drawer is relatively clean/unclogged
What I do as workaround (i.e. to speed up the machine)
When I notice that the machine is stuck, I just manually move the program dial forward a notch, so that the machine moves on to the next action. This is despite the instruction manual advises never to do that. This manual action allows me to get a cycle duration down to a more acceptable time (i.e. 2-2.5 hours)
My questions
  • Is this symptom linked to a known/predictable cause that a repairer can reasonably fix or am I better off getting a new machine?
  • Is there any danger that this issue, combined with my disregarding the manual instructions not to manually move the program dial, is likely to lead to unexpected outcomes (e.g. some electrical short-circuit)?
Dave White
  • 221
If moving the programmer forward a notch fixes it, it's most likely simply a failing stepper-motor on the programmer. I've fixed a similar vintage machine with a similar fault.
It's not terribly hard to fix, but the programmer can be fiddly to disassemble (in a "re-assemble-able" manner) because they have lots of gears. If you can get to the end-shafts of the steppers you can see which is failing by attaching a 'flag' or marking it, to see which isn't moving.
I believe these items are fairly generic; When mine failed, I went into our local appliance-repair store with the old one in my hand, not really expecting that they would have one, and would have to order it in. I'd barely opened my mouth, when the guy at the counter reached behind him without really looking and put a new one on the counter!
Obviously, the usual caveats apply; be careful when operating the machine with exposed mains, and rotating parts which can trap unwary fingers. It goes without saying that it should be unplugged before any repairs are attempted.
SiHa
  • 3,543
