All but one major room is part of a single path through home, from a window on one end to a window on the other. In the evening I want to bring in cooler outside air as efficiently as possible. If there is no breeze outside, is it faster to
  • close all windows except the two endpoints, setting up the box fan (which fits well in the window) to push air in or pull it out at one end.
  • open all the windows, and put the fan somewhere, without knowing exactly what the path of airflow from it will be.
The first method takes no advantage of whatever minimal passive airflow would occur with all windows open wide.
The second method doesn't make as good use of the fan, because it may end up cycling the air immediately around it over and over instead of reaching all areas of the house.
If passive circulation were truly nonexistent, then maximizing the fan's efficiency would be the way to go. Does it seem plausible that passive circulation could indeed be low enough for that to be the case?
rwusana
Moving air tends to feel cooler than still air. If you can put up with the noise, the box fan trick works quite well.
In my experience, air movement in the home depends on air movement outdoors; if it's a still evening, even with lots of windows open, you won't get much air. On the flip side, even a small breeze can help.
If you have lots of money and live in an amiable climate (cool, dry nights), buying a modern whole-house fan may be a good fit. Modern units suspend the fan itself from the rafters via an insulated duct, and are much quieter than they used to be.
As Jimmy Fix-it commented, the best thing to do is to try both of your methods.
Michael Karas
  • 67,833
  • 68
  • 153
supertanker13
  • 333
Previously I had a home with no A/C, it was in a forested area so not too bad. But to cool overnight, I put 2 box fans in the living room (great room) windows, both BLOWING OUT. I also blocked off parts that the fans didn't cover in the two windows. Then in other rooms opened windows which allowed cooler night time air to enter the room. I wouldn't use the "push - pull" method you described. It would only function in the immediate room space and probably not do much for the rest of the house.
So the cool night time air entered other rooms (mostly bedrooms) and got expelled via the fans in the living room. Worked pretty well. Sometimes got a little too cold in the BR for the wife, but it worked.
Hope this helps.
George Anderson
  • 23,304
  • 83
If this will be long term, a whole hose attic fan is excellent, I have had them in 4 different houses. Get a belt drive because the direct drives make air noise because of higher RPM ,smaller fans. You can install it in any room although the instructions say to put them in a central location. My present one is in a utility room in the corner of the house and works fine. Open the windows more in the rooms you want the most airflow. Our 24" two speed fan will make it uncomfortably windy on low speed if I only open windows in three rooms. In winter , I did pull off the belt so the fan will not run and lay insulation over the louvers to slow heat loss; but now that I am older ,I don't bother. Noise was only a factor in the one direct drive fan as I made the mistake of putting it in a central location which was a hallway outside bedrooms. Cost was not a factor as I put them in myself and the fans are cheap.
blacksmith37
  • 8,401
Because you're renting, I'd close draperies during hottest part of day (light =heat). After sunset, open draperies/windows on both sides and turn on your kitchen exhaust fan in addition to the box fan, to determine if it creates a sufficient draw of cooler air into your home.
Mary
  • 101
