I want to build a bench with a 450mm overhang from the legs (long story why I need the overhang, and I already have the legs which are heavy duty steel monsters). The bench will not hold anything heavy, but I want it to be very sturdy and last a long time.
Having a look at the local timber yard, my easiest options seem to be Pine, Oak, and FormPly.
What thickness do I need for a 2100mm by 600mm bench, with 450mm overhangs from the legs on each end? Should I run a batten underneath it? What size? Any batten have to be near the back of the bench.
Also, what varnish/paint should I choose that is hard wearing? I'd like it to be very dark (almost black would be ideal).
DMoore
  • 50,637
  • 93
  • 208
Abhi Beckert
  • 193
Ok, I did the metric to inches conversions so I understand the size of your project. Sure wish the USA would go metric like the rest of the civilized world. LOL.
Your bench is going to be apx 7 foot by 2 foot with 17 inch overhangs. I think you will find that a solid stable material like 20 mm (3/4inch) plywood, medium density fiberboard (MDF) or solid boards will work well if the load is not too heavy. Avoid materials like cheap chip or particle board because they have a tendency to warp easily if not secured to a sub-straight. Because the surface is not real smooth, they don't look great when painted.
If you want to be sure the unsupported overhangs don't curl or distort, you could frame under the exposed sections with an extra parameter rim of say, 2 to 3 inch by 3/4" solid stock mounted flat under the overhang. This would effectively make the overhang 1 1/2 inch (38mm) thick.
Use a good grade stain blocking primer and finish your project with a couple of coats of quality enamel paint.
shirlock homes
  • 58,628
  • 87
  • 168
