How can I cut the arc as shown in the photo?
I have a circular saw. I have a jig saw.
I thought I might calculate the center of the arcs circle and (using a line tied to my circular saw) cut the curve on a clamped down 1 x 4.
I don't have a very steady hand when it comes to using my jigsaw so I don't want to draw an arc and then cut it.
How do professionals cut arcs?
The arc I want to cut looks like this:
Source
Machavity
  • 26,498
  • 44
  • 100
Marinaio
  • 1,674
  • 48
6 Answers6
16
Whenever I want an arc that accurate I use my 3hp router (a smaller rated router will do too, just for smaller scale work) screwed to a shop made pivot (trammel) and make repeated passes, next pass deeper than the last to complete the cut.
A circular saw may make that tight of a curve if you set the saw shallow enough to just cut through the material. It will be quite rough, not recommended for finish work
Here is the formula to figure the radius of a given arc.enter image description here
Jack
  • 38,117
  • 66
They don't use a saw to cut them.
If you're the IKEA kind of professional, you have a monstrous milling machine. You program the arc into your CNC machine, and it just happens.
If you're a carpenter, you rough-saw to the basic shape you want, plus a bit spare. Then you use a spokeshave, which is essentially a plane for curved surfaces, to bring it to the exact shape you want.
Quite apart from the accuracy issues, a saw always leaves marks on the cut surface. If you care about the finish, you don't use a sawn surface as-is - you always use some way to take off a bit more wood and get rid of the saw marks, as well as getting the shape fully accurate.
Graham
  • 2,036
I used an arm screwed to my router to cut a curve in a benchtop, it worked well.
The same technique could be applied to a jigsaw.
screw a wooden block to the side of your jigsaws foot screw an arm to the block coming off at 90 degrees to the cutting direction.
mesure the radius you want from the blade along the arm and put a pin (nail) through it at that location
clamp to your work another block same height as the first with a hole to accept the nail at the axis of the arc
Put the arm nail in he block hole
The jig saw will now be able to cut a reasonably steady arc.
Jasen
  • 26,920
  • 46
Your jigsaw can do the job, but it's far too prone to wander for a perfect line. But you can rough cut it below the line and then use some sanding to get it to the line you want.
I would buy a new blade for this and make sure it has a high tooth count and/or is listed for fine or scroll cuts (if you're a masochist, you can try with a metal cutting blade, but that will likely take multiple blades for this size cut). Then take your time and err on cutting the part you're removing. For such a large cut, I would expect to take 30-45 mins slowly working your way around the circle. Then you can take your sander and hand tools and work out the remaining parts.
If you have a ton of time, just cut the bottom of your circle out with your circular saw, then cut the arc with a coping saw. But that has the same net effect as your jigsaw, just slower for the sake of precision.
KRyan
  • 167
Machavity
  • 26,498
  • 44
  • 100
Since no one else has suggested it, a bandsaw would work well for this curve.
Depending on how big of one you have access to, you might need to increase the size of the material support plate. And, in this case, having a wide blade would help prevent wandering. You could easily rough it in fairly closely with the bandsaw, then use a large spindle sander or belt sander to finish it off.
You could even build a jig to help with the cut, similar to how people cut round table tops with a bandsaw, except that the scrap piece is the part you want to keep. This is just one example of a jig I found, but there's many out there to find.
https://www.youtube.com/watch?v=N6_2h-vo0jA
To find the center of your circle/arc, draw a straight line between any two points on the arc, then find the exact middle of that line. Starting at that midpoint, draw another line at a 90 degree angle towards the center of the circle. Repeat the process again and where the 90 degree lines cross, that's the center. Repeat the process again to be more accurate, and to find out if you have an ellipse (oval) or an actual circle. With an ellipse, the 3rd and later 90 degree lines won't cross at the same point as the first 2. To make sure that you aren't accidentally creating a false center, make sure you don't reuse any points on the arc.
https://www.instructables.com/id/How-to-find-the-center-of-a-circle/
This is likely how a carpenter or handmade woodworker would make this curve. Not everyone that would do this kind of cut is IKEA (as mentioned in another Answer) and have access to a CNC router. I built my own 4'x8' capacity CNC router, but that's beside the point.
I realize not everyone has a bandsaw or large sanders, so you might want to find a local makerspace to see if the have that stuff. Makerspaces often have pretty good woodworking tools, but that varies with the organization. I've seen makerspaces that just have 3D printers or just have computers for internet and other IT related uses.
You might (but not likely) be able to find someone willing to help you with this one project, but becoming a member will give you access to all that equipment (based on their rules for it all). It'll also give you access to more build space as well as lots of people to help you figure out problems and even help with your projects. Yes, they will be willing to help other members (depending on their time and experience), even if they won't help the random walk-in.
computercarguy
  • 1,899
It's possible to cut coves on a table saw. This is kind of like a cove but on a very narrow piece of wood. But with the right amount of support I think it could be the same effect.
You can cut coves on a table saw by putting the wood through the blade sideways with lots of support on the front and back of the blade. Here's an example.
It's certainly not trivial and a jig saw/band saw/router would be easier but it's another option to think about.
Brad
  • 311
