I am planning to wire my house for Ethernet, with wall sockets in various rooms. At the moment it will be plain 1Gbit/s ethernet, but in future I want the potential to upgrade to 10Gbit/s and power-over-ethernet (POE). I am aware that there are wiring code restrictions on where power outlets may be placed. Are there any similar code requirements that would apply to POE sockets, or other practical considerations that would apply to their location (e.g. wiring constraints)?
Background
I live in the UK, in a 1930s house. This means: power voltage is nominal 240V, walls are constructed of solid brick with plaster facing (making it non-trivial to install or relocate outlets), wiring can run in the attic, under floorboards, or in the crawl-space beneath the house. There is no air conditioning; these spaces are ventilated but not used for air circulation.
I haven't bought any supplies yet, but I'm planning to use Cat 6, unshielded, Low Smoke Zero Halogen cable (assuming runs will be short enough for 10Gbit/s over Cat 6). I'm hoping to install standard metal back-boxes in the walls to mount 8P8C faceplates, probably with PVC conduit to take the cables down under the floor.
So far, I'm aware that data cables should not run parallel to power cables (to avoid interference), and definitely not next to each other or in the same conduit (for safety). However, for reasons of aesthetics and convenience, I'm inclined to put the Ethernet outlets close to power outlets. Many of these are currently mounted in the skirting board (which I'm aware is lower than modern wiring regulations suggest).
JRI
  • 143
Well, I will strongly suggest the middle of ceilings, because that's where you are going to want you POE wireless access points to be wired in for best performance, particularly in a solid brick walled house (very hard to get fast WiFi through brick walls at all.)
I will also suggest Cat6A if you have dreams of 10GB. While 6 is nominally good to 55m, the price differential is small, and 6A might offer some slight hope for whatever comes next for copper wires when 10GB is too slow.
But that also leads to my stock firm recommendation for wiring any building for network - use conduit, the cables become obsolete MUCH faster than the power wiring or the house. Being able to pull out your 6, 6a (or 5e if it's much cheaper for you now, though it's usually not that much cheaper) and replace it when you need something faster with whatever is in vogue then will pay off in the long run.
I don't know if the UK has any codes specifically regarding POE ethernet - in the USA as power-limited low voltage it has very little code affecting it (primarily the communications cable section of code, which does not have any notable location restrictions that I can think of at present.) Presumably as an international standard it might have been designed to avoid issues in most countries, but some may have more restrictive rules than is the norm for that application.
