I bought this MOYMO Room Divider Tension Curtain Rod, 122-150 inch. No tools or drilling required! I tried 2 Methods, but both failed.
  1. On ground, I insert curtain into curtain rod.
Method 1
  1. I pick a Spring Stop so that curtain rod matches length of soffit.
  1. Then I go to window and lift it up. Because curtain rod matches length of soffit, I got to push it forcefully between soffit. Curtain rod hangs for an hour, but falls down!
  2. I can't try Method 1 when it ruins my walls! When I push it forcefully between soffit, ends of curtain rod scrapes paint of walls.
Method 2
  1. I pick Spring Stop so that curtain rod just shorter than length of soffit. Then I walk to window with curtain rod NOT extended.
  2. I hold up curtain rod at correct height. Then I pick the correct Spring Stop that most extends curtain rod between soffit.
  3. But no screw hole matches length of soffit. Curtain rod won't touch soffit on both ends! End of curtain rod has space between right side of soffit wall! Now what?
0 Answers0
