This is for a bifold door. I want to have front and back knobs using the same screw.
I can’t recall what this assembly is called nor the screw name.
jlsdds
I don't ever recall seeing a "kit" for this. When I've had to do it, I just got the two knobs and cut the head off one of the screws. If the screws that came with the knobs were too short, then I got a longer screw and cut the head off. There are double threaded studs out there but they are usually too big for what you want to do.
JACK
  • 89,902
  • 214
"I think AM's point is that you need opposing thread direction on each end. The threads would be backward for one side. – isherwood." Totally wrong, you just need a suitable length of threaded rod or cut the head off a suitably long bolt. The thread doesn't need to be reversed. It's just the same as putting a nut on each side, you wouldn't need different threaded nuts. Threaded rod doesn't cost that much and you'll have it for future projects, working out much cheaper than buying bolts. If you've never cut threaded rod or a bolt before, put on a nut each side of the cut first, then when cut file the edges and thread slightly at 45degs, before taking the nut off to reset the thread. If you don't, sometimes you'll find a nut doesn't go back on easily or you can cross-thread the nut. Hope that makes sense!
Just use a
no-head bolt
and buy two handles.
Probably want about 2 1/2" length (although depends on size of handles)
Alaska Man
  • 13,792
Vette
  • 195
