I'm trying to understand when to use what method to seal, to prevent air and/or water.
When would a tape like Wigluv be preferred over caulk or low expansion foam? What applications is it the ideal choice?
Asked
Active
Viewed 229 times
J. M. Becker
- 538
- 5
- 18
A thick tape like Wigluv would only be used where a flat surface isn't needed or any such bulge will be concealed.
Caulk would be used for small and shallow cracks or gaps (1/8th inch or less wide) and a flush or completely flat surface is needed.
Foam is for moderate to large gaps (1/4 to 3/4 inch, depending on foam type) and deep or full depth straight through filling.
Of course, all 3 can be used, or any combination of them, that addresses the need for a specific result or longevity.
Iggy
- 10,392
- 18
- 36
You would prefer tape when you don't want to wait for caulking to cure or when applying to a gap of varying sizes where caulk is only suitable for part of the job. Tape is likely faster than intermittent backer rods -- time is money.
Matthew
- 10,823
- 23
- 64
- 109
