20
In my house, I fortunately have a well-labeled circuit breaker. There are a few rooms that could be better named, but it's fine.
As such, it's very easy to identify almost every switch and what it does and what breaker switch it's attached to.
Except for one light switch at the entry way of my house.
I turned it on and stuck a voltage tester next to it. I went through every single breaker switch, even the ones for other floors, and the voltage tester continued beeping. I skipped the doubles (washer, dryer, and HVAC), because I assume a light switch wouldn't be connected with a major appliance.
I've also tried plugging a light into various outlets and turning the wall switch off and on, but I don't see any change in the light.
The voltage tester only stopped beeping once I turned off power to the entire house. So as far as I can tell, this switch seems to do nothing.
  1. Is there another method I can use to trace what this switch connects to?
  2. What should I do with this switch?
Update: I have finally figured out where this mystery switch goes to: an outside outlet. I never even noticed it until y'all pointed it out so thank you! I still don't know which breaker it goes to, which is annoying but I've got at least half the mystery solved
Update 2: I have found it! Once I realized it went outside and was GFCI, I guessed that the cable was connected to the Basement GFCI circuit and that did it. Personally I would have labeled it "basement + outside gfci" or wired it to the first floor outlets or put it on a separate breaker but it's fine. I'm not bitter at all
Merlin -they-them-
  • 485
Divide and conquer.
You turned off the main breaker and the switch went dead. So you know it is going through that panel.
  • Leave the main breaker on and turn off everything else.
If it is still on at this point, then you have something really strange going on - time for a professional. But assuming that does turn power to the switch off:
  • Turn on the breakers one at a time until the switch comes back on.
This will take a while, so you can also try:
  • Turn HALF the breakers on and see if the switch comes back on.
If it does, then turn half off and see if it is on or off. Lather, rinse, repeat. If you have 32 breakers, the first test gets you to 16, the second to 8, the third to 4, the fourth to 2, and on the fifth test you have your answer.
As far as what the switch does, is there any chance you have some outside lights that don't work properly? Also look for any receptacles or covered junction boxes (which might previously have had a light on the switch) outside.
Update: Now that you have determined the switch controls a receptacle, there is an easy way to find the breaker if you don't have a helper (i.e., if you have to run between breaker panel and switch/receptacle to test):
  • Plug a radio into the switched receptacle.
  • Turn on the radio loud enough to hear it from the breaker panel. Might be best to do this during the daytime :-)
  • Turn off breakers one at a time until the music stops.
For anyone wondering why "turn off one at a time until the music stops" instead of "turn on one at a time until the music starts", this gets to the "old vs. new equipment" issue. An older radio has a simple power switch. Turn it on and unplug it and plug it back in and it is guaranteed to be "on". Many newer radios (like TVs, computers, etc.) have a power switch that does not really turn everything off. A small circuit stays on to power a clock, status lights, etc. For normal usage that's just fine. But the default behavior (sometimes configurable, sometimes not) for these devices is typically "on external power restore go to 'off' state", which wouldn't be very helpful here.
  • 139,495
  • 149
  • 386
One problem with using a non-contact voltage detector is that it can be befuddled by adjacent circuits. To really determine if the switch is powered or not you need to remove the switch cover and attach a wired voltmeter to what you perceive is the "hot" wire in the box.
And, unfortunately, this is not even 100% reliable if the voltmeter is an electronic "high input impedance" unit. When faced with this possibility I dig out my 50-year-old Heathkit meter.
Hot Licks
  • 2,103
You can buy a tone wire tracer (sorry I don't know the name in English) in several electrical stores or online, their use is fairly simple, first remove all electrical power, then you attach the generator on one side and with the tip tool start moving around the wall to follow the path that gives you the loudest sound, with that you can follow the cable all around your house and trace it to the end
https://www.youtube.com/watch?v=UAEq-yvjryQ
Chico3001
  • 151
If you're turning off breakers one at a time and it's still registering a signal then there's possibly two circuits going through that switch box, there is a live wire behind the wall which is neighboring that switch box, or the switch's wiring is simply getting cross-talk from a neighboring wire somewhere before or after the switch.
You should turn off all breakers and turn them on one at a time. Once a breaker registers a signal then make note of it and turn it back off. Then continue turning on the rest of the breakers one at a time.
MonkeyZeus
  • 17,328
  • 64
