Until I decided to replace a couple of ~16-inch long, beveled-siding from exterior I have never given thought on the width of the exposed face. On my house, the exposed face of the cedar siding measures 4". When I removed the old pieces, I noticed that they are 5-1/2" wide (actual size.) My replacement pieces were also 5-1/2" wide. This means that overlap between the beveled pieces are 1-1/2". And the nails were put ¾" to 1" above the bottom of the planks. This means that nail goes through the overlapping piece under, and most likely cracks it.
At the beginning I did not make anything of it, since I had no clue. However, when I did Google search, I have realized that every website recommends that nails should not go through the bottom piece but slightly over it. Now, with the current overlap size of 1-1/2" and where the nails are put, that is not possible. I have big house and all the exposed faces measure 4" or slightly narrower to 3-3/4". The house is 30 years old.
I am wondering if the builders did it wrong from the beginning, or installation instructions changed in the past 30 years. I have some other cracked beveled siding which are as long as 14 ft long. I just wanted to get an opinion before I start my repairs. Should I overlap them as it's (ignore if it cracks) or should I cut the siding to a narrower size so that nail does not pierce the plank underneath. Or Should I put the nails slightly higher than 1-1/2 inch from the bottom of the plank, to avoid the the plank under. Thank you.
Supertech
  • 307
The short answer is that it just isn't that critical. There will still be enough unpierced lap to provide weather resistance, and the sliver that cracks off the top edge usually doesn't result in a problem. In a rare case the wood grain angles down far enough that the crack shows, but that's not likely.
Longer answers involve the need for wood siding to have a little room to move and flex with seasonal changes, but that describes an ideal that isn't at all critical. I've owned homes sided with cedar lap for decades (some of which I installed decades ago; I'm in one now) and it has been an issue that the top edge was nailed exactly zero times.
