12
I have an unfinished basement that always has tons of beetles, spiders and cold air (yes I know most basements have this, but it is more than normal). I finally decided to take a piece of insulation out that sits on top of the foundation between the floor joists and there is a gap between the top plate and floor joists where you can see light getting into the house and a substantial amount of cold air coming in.
Is there any reason I can't fill this gap with something? Also would you guys use expandable insulating foam or something different. Blow are pictures for reference.
Josh
  • 129
This is a perfect scenario for spray foam, which both seals against airflow and adds insulation value. Pick up a couple cans and seal all such joints, then overlay fiberglass batts that match or exceed your wall insulation thickness.
Be aware that the standard foam swells to many times its initial size. Use small beads and try to force it into the void rather than just covering the surface. Also be aware that urethane does not come off clothing, skin, and almost anything else. Wear gloves and old clothes, and cover any surfaces or objects you need to protect, including outside the gap. Leave any bulge alone to cure, then tear or cut it off. Wiping it usually makes a mess.
You might also use a silicone or paintable latex caulk on the outside face of that gap, though. I do wonder when there's no exterior covering at that point. Does the wall sheathing not extend onto the sill plate?
Isherwood is right on the approach - spray foam or caulk - or both (caulk first). I however want to add... If I had a crack this big I would block it off with a 2x4 or even 1x's. This is mouse heaven and caulk/foam aren't keeping mice out.
DMoore
  • 50,637
  • 93
  • 208
