-1
I am living in a building where I wish to run Cat 6 cables to different rooms.
The building is constructed using bricks and concrete.
The electrical wiring is running in PVC conduits.
The electricity is at 220V.
I know the electrical wires cause interference with ethernet cables but I was wondering if it possible to run outdoor certified CAT-6 in the same conduit as the high-voltage electrical wires. The outdoor certified cables have an extra layer of protection so I wanted to know if that would allow both types of wires to be run in the same conduit or not.
Saad
That is not the case. Ethernet cables are very immune from power line interference. They are constructed using twisted-pair wiring and differential inputs to the equipment. So any induced signal are self-cancelling.
But you should NOT run AC mains and any low-voltage wiring (such as network, telecom, alarm, cameras, etc.) in the same conduit. You should use at least two, one for HV and one for LV.
jwh20
  • 23,628
  • 65
You cannot run data cable in the same raceway, conduit, gutter etc. as AC mains electrical wires.
The only exception is low-voltage circuits that are entirely contained within AC mains-rated junction boxes and enclosures. That's how it's legal to install things like the Sense home energy monitor; the entire kaboodle sits inside the service panel (which is obviously mains rated), and nothing but a WiFi antenna sticks out.
What you definitely cannot do is have an Ethernet in the pipe with power wires and have it come out to an Ethernet cover plate where you then plug in a cable and plug it into the back of a PC or Roku box. Of course that's what you wanna do, right? :)
That's why there's no such thing as a receptacle with one 120V socket and one Ethernet socket. That would never be allowed. (well I'm sure someone in China makes it and sells it on Amazon, but it's illegal as heck. Amazon is as junked up as eBay these days).
Fiber optic, however, is a different deal. If the fiber-optic cable is entirely non-conductive (you must check), then yes, that can go in and out of AC mains conduit all it wants. So a receptacle with one 120V socket and one fiber socket is legit. Ethernet-fiber converters are cheap these days.
Bad idea , dont do it .
220v = 2phase ,alot of angry pixies if it goes short circuit , i assume your in the US.
In addition to the above posts , by adding another wire you change the thermal dissipation of that cable within that conduit, potentially derating the permissible current allowed on that cable.You could potentially overheat that cable by adding more cables.
Food for thought...
binaryOps20
  • 460
