I am in the planning stage to finish my basement. There is a rough-in with drain for toilet and shower. My plan is to add at least two bedrooms with one being a master. Thankfully the rough-in is located in the middle-ish of a long wall.
Is it possible to add a half bath immediately adjacent to the master bath in such a way that the toilets share a 4" drain without tearing into the cement?
If necessary I don't mind raising the floor to create a 1/4"-per-foot downward slope. Assume that the drain and main stack are equidistant between the two toilets on either side of a common wall.
Are there any problems with this in terms of flow or venting? How would one go about it?
Alaska Man
  • 13,792
Tag
  • 319
You are "f'ing" crazy if you think that raising part of your floor is easier than doing some very very minor concrete work. There are all these gotchas for raising a floor and then finishing it so it doesn't look ghetto.
Now for doing it right there is breaking concrete, creating a bed for pipe, laying pipe, backfilling, and then adding in quickmix concrete. It is 8 hours of work. You will spend days trying to figure out how to put a toilet on an elevated box that looks OK.
Just do it right. The elevated floors should be a last case emergency thing. I have finished hmmmmm maybe 50+ basements never have I raised the floor to tie into the stack.
Also from a DIYer perspective, when you are breaking the concrete and filling... there is nothing anyone can see. You can mess something up or have a half assed finish and no one sees it. You raise floors and every carpentry thing sticks out like a sore thumb, every edge, every finish. You may be scared to break the sledgehammer out on the floor but in reality you are creating 5-10 times the work for yourself AND IT WILL LOOK WORSE EVEN IF YOU FINISH IT GOOD.
Note: The hardest part of breaking up a basement floor is carrying buckets of concrete out (assume 20) and disposing them. Everything else is really easy. I did want to mention this because it is a workout.
DMoore
  • 50,637
  • 93
  • 208
With a 9’ ceiling you can do what you want without cutting the slab. The only negative is there will be a step into the bathroom (not a horrible thing I have had to do this for a 1/2 bath because the drain itself was directly below the slab on 1 house. I would be aware if there are roughed in showers, those traps will be below the concrete normally and you don’t want 2 traps that would not drain well. So there is a possibility of an issue there. If everything is replumbed to the 4” I don’t see any major issues with a 9’ ceiling.
Ed Beal
  • 103,727
  • 79
  • 158
