I have replaced an old intercom in my top floor flat (which was always rubbish and crackly) with minimalist approach. A basic ding dong chime that’s nice and loud and a light switch to open the door interlock.
I’ve found the two wires from the old intercom which unlock the door for the building and wired that up to the light switch (works perfectly) and can leave it switched on while I stick my head out the window to check guests have got in before turning off. however. I’m struggling with the chime...
I’ve bought a Byron Chime from screwfix which I have wired to the mains and can trigger the chime with a short piece of test wire. Next step, I have then found two suitable wires from the old intercom which have continuity when connected together with my doorbell, but when I connect these to the chime they don’t seem to make it chime! (I can hear a feeble buzzing noise like it’s struggling to trigger the solenoids)
Using a multimeter I read 0.4 ohms when touching them across my short piece of test wire, but the wire loop to the front door reads 22ohms. Is that resistance too much to trigger a chime?
If so how can I amplify the connection in these wires, or lower the signal needed to trigger the chime or is it something else altogether that I need to be doing.
Many thanks in advance. Charlie
0 Answers0
