I have an enclosed cargo trailer. I need to install some rivnuts in the roof beams from the outside of the trailer. The aluminum skin of the trailer is attached to the steel tubing framework using some sort of adhesive. The result is that the aluminum is not directly against the steel tube. When the rivnut is installed, the deformed part of the rivnut ends up between the aluminum skin and the steel tube instead of inside the steel tube. This results is a much weaker anchor.
The following pictures shows the problem:
These are three different cross section drawings. Looking at the left one you can see the aluminum skin on top and the 1" wide x 1.25" tall steel tube. Between them is the layer of adhesive. I have no access to the underside of the steel tubing (which is why I am trying to use rivnuts in the first place). Removing the adhesive is not an option for several different reasons.
The rivnut is just placed into the hole in the left cross section.
The middle cross section is the result I am getting after compressing the rivnut in place. Note the compression is happening where the adhesive is.
The right cross section is the result I wish to get with the compression inside the steel tube.
The tool I'm using to install and compress the rivnut is little more than a big nut on a grade 5 bolt.
How can get the rivnut to install as shown in the right-most cross section shown in the picture? Would a different/better tool work?
The nut on my installation tool has a slight lip on it about the same height as the flange on the rivnut. It seems that if the nut had a taller lip on it (the same as the thickness of the aluminum skin, the adhesive, and the wall thickness of the tubing) then it might work.
rmaddy
  • 145
You need a longer rivnut where the compressive section is further away from the head.
Or remove the adhesive layer and then the rivnut will work correctly .
Solar Mike
  • 30,038
  • 69
I think that part of your problem is your use of the super economy installation tool. With that kind of tool it is difficult to hold the rivet nut very firmly into the hole.
I use this type tool for installing rivet nuts and have had good luck with its use. The tool allows you to press down firmly on the rivet nut while at the same time folding the handles together to compress the rivet nut.
Picture Source
Rivet nuts are designed to allow crimping into materials in a certain range of thicknesses. They do require a hole through solid material that is a snug fit with the body of the uncompressed rivet nut. It is quite possible that you will never achieve a satisfactory result with the soft adhesive material between the outer skin and the metal tubing. One thing that you may want to try, after obtaining a better installation tool, is to heat up the area surrounding the installation site for a four or five inch area to soften the adhesive. Then with the better tool you may be able to compress the softened adhesive a bit when pressing hard down on the compression tool.
Michael Karas
  • 67,833
  • 68
  • 153
