My entry door threshold is sunk into the concrete from the driveway and leaking.
How can I repair this sunken threshold?
OR, what kind of contractor should I get to repair it for me?
Alaska Man
  • 13,792
Hard to confirm without pictures, but you might have a void below the wood where water gets in and is causing the wood to rot.
Remove the rubber gasket, then remove the metal threshold (if you have one). Next remove the rotted wood. You may have to cut away since the wood will run under the jamb. Fill the void (if there is one) with quick setting concrete. Then just replace the wood. Use pressure treated wood to prevent rotting.
OR, just hire a repair/handyman.
EMAW2008
  • 407
