16
I have a Bosch PSB 650 RE hammer drill, with a keyless chuck:
The chuck mechanism involves a button on top which, when pressed, allows the chuck to be tightened or released, rather than just rotating with the bit.
The other day I did some drilling with an 8mm masonry bit (in hammer mode); and after drilling - the chuck would not release. I applied as much torque as my hand could stand, until it was quite sore from the friction against the plastic.
My question: How do I release the bit from the drill?
I'm hesitant to try pliers or a vise grip, worried I might just file down the plastic and make a bad situation worse.
Notes:
  • The chuck was not overtightened - just the usual tightness. So this related question is not quite my situation.
  • I'd rather save the drill bit than break it; and would also not want to damage the chuck jaws.
einpoklum
  • 3,145
  • 25
  • 42
5 Answers5
34
I recently had the same issue and tried numerous solutions with no luck. In the end I purchased a strap wrench: This kind of wrench grips the object via a strap or a chain:
You basically put the strap around the chuck, tighten the strap and then use the wrench handle as a lever to gain more torque while trying to undo chuck. This worked extremely well.
I simply wouldn't bother with any other solution in the future.
einpoklum
  • 3,145
  • 25
  • 42
user79408
  • 421
I've had this happen when hammer drilling as well and I put the drill in reverse and stuck the drill back in one of the holes. This was able to loosen the hammered death grip the chuck had and I could easily remove it. Although, if you do it too long it might remove the drill bit from the chuck.
Mr. Anderson
  • 381
Try the following "low-intensity" method:
  • Apply WD-40 (or other similar "penetrating" material?) generously to the maw of the chuck.
  • With a small hammer, gently tap different points on the chuck's surface, from different angles. Nothing that would cause a dent, just slight mechanical vibrations. This may help WD-40 seepage.
  • Wait a while (an hour maybe?) for the WD-40 to work its magic - but make sure the drill is in a position where it doesn't just spill out, i.e. maw facing up.
  • Now try releasing the chuck again.
This worked for me, possibly because I had not bothered to clean the chuck in any way since I had bought the drill, over a decade ago, and the mechanism might have gotten jammed with some concrete dust or what-not.
Notes:
  • I mostly followed this Youtube video.
  • Cleanliness: Make sure to drain any remaining lubricant and gently wipe the drill so not to get WD-40 over your toolbox. Also, perform the whole procedure over some paper towels or multi-page newspapers etc.
einpoklum
  • 3,145
  • 25
  • 42
This might sound like a ridiculous "one simple trick..." but ...
The solution here is a strap wrench.
if you don't have a strap wrench, what do you do?
Put on a latex glove.
Note - or any similar material, "a rubber glove" in the broad sense.
It is just absolutely amazing how much gripping and indeed turning power an adult human has in the torso-arm-hand system.
However, humans are designed to be really, really slippery: we have useless traction.
If you haven't before tried your hand + simply a latex glove, in such "stuck jam-jar lid" situations, it will amaze you. Enjoy!
Note that, self-evidently, everything should be bone dry when you do this (but that applies precisely to using a strap-wrench).
Fattie
  • 229
Had the exact same problem with a similar drill. Could not get anywhere, until I realized that front grip has a tightening mechanism. So I removed the grip from the normal use position, and used the mechanism to tighten it good around the chuck grip instead. Gave me the exact leverage I needed to open it. It's a similar solution to using the strap wrench by user79408, but don't require additional hardware.
Remy
