I recently became aware of the need to bond a gas distribution containing yellow CSST flexible pipe. (TracPipe FGP SS4 750 5 PSI FUEL It has a yellow jacket)
When our propane system was converted to natural gas the contractor used a combination of existing iron pipe and yellow CSST pipe. The current system starts with 50 feet of CSST pipe at the meter connected to a short iron pipe manifold near the furnace. A second separate 20 foot section of CSST pipe runs from the manifold to a section of iron pipe serving the water heater. The manifold also feeds the furnace with iron pipe and the fire place with another section of CSST pipe.
The meter is on the opposite side of house from the electrical entrance and the electrical panel.
I see no attempt to bond/ground the gas piping.
It looks like there may be a dielectric union on the house side of the gas meter but I have not verified that the house is isolated electrically from the meter.
My questions are:
What is the proper way to bond such a mixture of CSST and iron pipe?
Does anything need to be done to insure that the three runs of CSST meeting at the iron manifold are electrically connected?
Can the system be bonded at the meter to a ground rod? Can the system be bonded to the electrical panel from the iron pipe serving the water heater?
I hope to find a knowledgeable contractor to do this work but I want to understand what needs to be done.
