14
It’s triangular with a thick solid 3 legged base, multiple flat wired blades (possibly blades), has a handle, and the rear legs are slightly higher than the front leg.
JamG4
  • 281
The mystery has been solved, and it was discovered to actually be a vintage aluminum iron stand. I had found many antique iron stands that were similarly shaped, but none had the blade like structure around it. I assume their purpose is to prevent the iron from falling off while allowing heat to escape.
FreeMan
  • 48,261
  • 101
  • 206
JamG4
  • 281
