The lightbulb on my freezer went out, the freezer is a Frigidaire FFFH20F2QW. I've tested the actual socket, and it seems to be working, so I'm pretty sure it must be the bulb.
I see the the official replacement bulb is part number 5304517886. This part is an LED bulb that is relatively expensive.
  • Is there any other part that fits?
  • Is the base a standard socket size?
  • Is there an incandescent part number that is cheaper?
I've tried to google for the above answers, but wasn't able to find clear answers. Any help is appreciated..
Jeremy
  • 133
A quick googling suggests you are dealing with an Edison E17 type base. This is the third most common base in North America, after E27 (normal) and E10 (candelabra). 17 = diameter in millimeters (think slightly smaller than 3/4").
You should be able to be able to use any 120V LED bulb with an E17 base. Be wary of mail order especially Amazon.
I would not use an incandescent bulb because the freezer's socket area may not be built for the heat of an incandescent.
