17
This has been in my garage for a while, but I have no ideas what it is. Anyone out there know?""
Eric V
  • 171
It is a gear puller. A two and and three arm, use to pull gears/bearings off off shafts/holes. Use the bolts to connect a pair of flats to the centre piece to the arms. The long screw goes in the centre hole, place it against centre of a shaft, the arms go to outside of gear and you turn the screw to remove gear from shaft.
crip659
  • 32,986
  • 39
  • 85
