I had 4 layers of old linoleum on my porch. I was able to remove it easily and get back to the plywood, but the first layer of adhesive remains. It is fairly smooth but there are places where the adhesive clumped and I am worried about the peel and stick plank flooring not adhering to it.
What can I do, aside from buy a different flooring, which isn't possible, to remove the old adhesive enough that our new flooring will stick?
I was told that my best bet may be to lay another layer of plywood over top - is this my only option?
FreeMan
  • 48,261
  • 101
  • 206
Shawna Butler
Products with an adhesive backing work best on uniform substrate.
Per:
It sounds like the old adhesive has completely dried up so you can used a random orbital sander to sand down the high spots and make the entire subfloor more uniform. A belt sander could also be used but you'll have to be extra careful to not gouge the subfloor.
However, take precaution to ensure your old flooring and adhesive does not have asbestos.
Asbestos in adhesives
Asbestos in Vinyl products
Tacking down a thin, 1/8" or 1/4", layer of plywood is certainly the easiest and safest solution albeit might not be the most cost-effective.
You should still sand down at least the high spots or else the bulge will make itself quite visible over time through thin plywood like I suggested.
MonkeyZeus
  • 17,328
  • 64
I would rent a plate-style flooring sander. It'll result in a much flatter final surface, and it'll be much quicker than a hand sander. They're not expensive to rent for a few hours.
Use a fairly fine grit. Don't use the crazy coarse stripping grits that they offer. I'd maybe do 80 or 100.
Once that's done look over the fasteners. You may have removed some heads in high areas. Add screws where necessary.
