I have a Murray LC116DS circuit breaker panel. I want to replace the standard breakers (some alien) with AFCI's and GFCI's. I also want to be able to move these expensive breakers to a new subpanel in time, when I am ready for the generator transfer switch.
From the panel paper it can use:
class NI Murray MP & EP, ITE EQ-P, or Westinghouse Quicklag P.
From this topic: Murray Universal breaker it appears that Siemens makes Murray replacement breakers. From Siemens' website I got the Murray-to-Siemens cross-reference spreadsheet (Excel file) and I see that Siemens Q series replaces Murray MP series. So a Siemens Q115DF 1-space 15-Amp Dual Function AFCI/GFCI might replace a Murray MP MP115 1-space 15-Amp regular breaker, etc.
I also eventually want to put in a subpanel next to the Murray, with an appropriate generator transfer switch, and I'd like to move many of these expensive breakers to the new panel at that time. Here is the space I hope to use:
The black pipe may limit my panel height. Perhaps the Siemens SN or PN series, 100-Amp 30-space 30-circuit panel, about 28" tall, might be OK. The panels for sale are all plug-on-neutral now, but Siemens literature says their pigtail breakers will fit in their plug-on-neutral panels.
Does this plan make sense? Or do I have to do or use something different?
I understand that adding the subpanel may require a permit and inspection. But will the first phase, replacing all the breakers, require permit and inspection?
I am in New Jersey USA. The only major electricity user in the house is the central air unit. Stove, water heater, dryer, furnace are all natural gas.
Edit: adding another picture showing the panel wall, pipe and start of stairs, with dimensions. The drain pipe is 36-38" above the floor. The duct is 64 3/4" above the floor and 30 1/2" from the wall. The rafters are 69 1/2" above the floor. The open space from the stairs to the left wall is 64". The panel is 10 1/2" off the left wall. The front edge of the pipe is 4" from the wall the panel is mounted on.
