22
Got this at a yard sale in a bin with mostly random fasteners. Its about 3" long. It is very similar to a standard framing nail in diameter, if not slightly less. It has a tip like a nail but a dipped-looking rubberized coating.
Any ideas what this could be for? Someone suggested a small awl but given the very small size of the "grip" (if that's what it is) that seems unlikely.
I am in the USA.
StayOnTarget
  • 5,675
  • 58
  • 102
5 Answers5
38
From the Harbor Freight Hook Assortment (item #67587), it's a straight line "hanging hook."
As noted in comments, it is a padded nail for hanging things. You hammer it in at an angle and then you can hang things on it. To avoid damaging the rubberized coating you gently walk the plastic off it, then drive it, then file down where you mushroomed it, then wet the plastic and slide it back on.
storage hook assortment
fred_dot_u
  • 11,958
  • 35
It's a scriber used for marking wood, metal, etc. for cutting or drilling.
JACK
  • 89,902
  • 214
Small pegs you can hammer into a board where you can hang things on, like a towel or your size 10 wrench
Tschallacka
  • 357
Hardened point - then a tile cutter.
Solar Mike
  • 30,038
  • 69
-1
That looks like a hand drill / hole maker. It is a type of awl (or, it could also be a bodkin for leatherworking or be a two-in-one as both) - thanks @StayOnTarget
It is used to facilitate screwing in things with your hands. (hooks, curtain hangers, etc). These are fairly easy to screw in, but it can be a lot of work to get the screw to engage. Punch or twist a rough hole with the tool first and then engage the screw.
Stian
  • 208
