I need to rewire a solar flood light so that when the switch is in the "on" position, the flood light remains on continuously being shut off at the switch. In the "off" position, the flood light would operate as intended, being activated by nearby motion, and turning off in a relatively short period of time afterward. The current wiring is as follows:
Two green wires leading from the on/off switch directly to the motion sensor. Black and red wires connected to the positive/negative battery feeds leading to a push on clip on the circuit board under label "BATT", B+(red) and B-(black). Blue and white wires connected to the solar and soldered on the other ends to the circuit board under label "SUN", S-(white) and S+(blue).
0 Answers0
