That's not a typo in the subject line.
I am finishing part of my basement to put in a new master bedroom, bathroom, and closet. I was planning on putting the panel in the walk-in closet but enclosing it in a full enclosure of the appropriate size (floor to ceiling, 30" wide, 36" deep), but the inspector said that is not allowable because the panel would be in a closet in a closet and since the outer closet is a clothes closet, the panel is still in the "vicinity" of ignitable materials. I don't quite understand this since there will be a solid layer of finished wall between the panel and any ignitable materials. Thoughts?
I then came up with a second idea to still create a "subcloset"; however, this time, it would have a small door leading directly to the bedroom. The panel would still have the appropriate clearance, but to get to that clearance, the "hallway" (about 3' long) would only be about 18" wide. Without me providing exact dimensions of the door, the inspector approved this idea via email but said the door to the panel must be at least 24" wide. Is this correct? Would this separate closet need a door of at least 24"?
Thanks!
FreeMan
  • 48,261
  • 101
  • 206
Cody
Electrical panels are something that you have to design around for a basement. Would you have the main stack running through the middle of your bedroom... No.
Why? Because it is common sense.
It is also common sense to not have an electrical panel in a closet for various reasons. So if you are going to build a room for your panel inside the closet you still have to abide by all of the normal restrictions. If he said 24" door that's what you have to do. I for one would change the design.
DMoore
  • 50,637
  • 93
  • 208
Everything the inspector told you is correct and consistent with the national electrical code. The door must be so wide to allow an electrician unencumbered egress in an emergency. Also to provide sufficient working space.
DrSparks
  • 1,831
