In a post-and-beam house (built from Douglas Fir), I will have a bathtub right next to a couple of the posts.
Should I be worried about the effect of water on the longevity of the wood?
The other posts in the house are bare (unfinished). Is it necessary to put a protective finish on these wet-area posts?
Jay Bazuzi
  • 11,778
  • 100
  • 143
I think you should seal the wood for two main reasons:
  1. the posts are in a bathroom, where they'll be subject to high humidity (possibly condensation) and temperature changes. That's a recipe for warping and splitting in any wood. Even with the thick posts used in a post-and-beam house, you'll still see some ill effects eventually.
  2. Doug fir is rot-resistant, but not rot-proof. If you do get condensation in that bathroom, you'll shorten the life of those beams if you don't protect them.
A third (cosmetic) reason is that untreated wood is going to lose color over time, becoming gray. I would recommend you think about treating all the exposed posts and beams, not just in that bathroom.
  • 20,909
  • 95
  • 135
you didn't mention if the posts were unfinished, stained, urethaned, or painted. The finish on the posts will make a huge difference in a moist or wet environment. need more info to help you with a good recommendation. However, without question, a bead of silicone at the base is gonna be a good idea. either use a paintable silicone or color match the silicone.
shirlock homes
  • 58,628
  • 87
  • 168
