Outdoor hot and cold faucets, idea was to attach 1/2 pex to faucets and run through 1 1/2 pvc piping about 12" under ground for an Outdoor sbower, before pavers are installed. Both pex lines fit in the 1 1/2 pvc, then arc upwards on each end until vertical. Due to supply chain issues, I could only find 1 1/2 pvc. Will it be too tight a fit to run both 1/2 pex together over the 30ft straight run? Or am I better separating hot and cold into 2 pvc runs or do I need a larger pvc pipe ( 2 inch or larger)?
Asked
Active
Viewed 1,030 times
If you tested that both lines fit into the PVC, then both lines fit in the PVC. If the two bends were made with a heat so that they are super long sweeps, then they won't give you much problem either. If you are using store-bought bends, then you don't have a chance. However, if the ends are short and the pex is installed into the straight pipe first, then the bend can be installed over the pex and glued onto the pipe last for a much easier job. I have created a few impossible pulls using what I call the 'install the pipe over the wire' technique.
Wire pulling lubricant always helps a lot and is often the difference between possible and impossible.
I find it interesting the you are putting the pex into another pipe.
Paul
- 1,018
- 5
- 6
