I'm trying to make a drawer face to match the other cabinet and drawer faces in my kitchen. They are all 1" thick, so I'd like to match that size.
I'm trying to buy some unfinished oak boards that I can cut to size and then route around the edges, but all I can find at Home Depot and such stores is 0.75" thick boards.
I found one place that will special order the boards I need, for US$100 for a 1" x 12" x 96" piece!
Where can I find true 1" thick boards (0.75" boards are listed as 1" "common size" on the website)?
Or could I take two 0.5" boards, glue them together, and then cut and route?
ThreePhaseEel
  • 87,685
  • 144
  • 243
rothloup
  • 755
  • 37
If buying rough hardwood (from a mill or reasonable hardwood supplier, perhaps even one that will plane for you), buy 5/4 or even 6/4 rather than 4/4 boards. 13/16" planed is about as much as you can hope for from 4/4 rough. Normally 5/4 should be plenty for true 1 inch planed.
For sure, find a wood distributor in your area. These cater to professionals and might chop up a long board for you with a circular saw so it fits in your van. My friends and I have bought oak and redwood from this kind of place. I got huge chunks of oak; 1" thick is no problem. They'll carry only common woods used for large-scale construction, plus some synthetic materials for decking etc. This will be the cheapest option.
There may also be a boutique wood shop in your area (I've gone to a place called "Wood World". This would be more expensive for such common woods, but cater to the woodworking hobbyist and can (for additional fee) do things like plane it and surface it for you. They'll have a wide variety of "interesting" wood, turning blanks, and plywoods.
I've also bought redwood from places that specialize in just that; they have lumber meant for fences and decks. I've bought 2x4s etc and cut and planed my own stock down from that. My friend bought ugly redwood from the general wood construction supplier; this is to make painted trim, and is cheaper than the pretty stuff sold for fences and decks. I forget what the grades are actually called.
I've bought wood online and had it delivered, dropped off in my yard. Shipping can be pricey, and it's only worth it for a large order or wood that's already expensive.
Go to the local woodworker hobby shops and ask around. Not Home Depot! Places like Rockler and Woodcraft. The sales clerk might know about such suppliers in the area, and even have business cards and a poster display in the store. Lacking such knowledge from a clerk, you might learn about clubs that meet locally, and you can ask there. In fact, for a small piece, getting a cutoff or scrap from a club member might be the cheapest by far.
JDługosz
  • 1,131
For the sake of convenience and maybe even cost you absolutely can glue two boards together. If you have a planer I would recommend using two 3/4" pieces and then planing it down to the required size. Make sure the boards are at least slightly oversized in all dimensions and then cut/joint it down to the final size and you will never even be able to tell that it's two boards and it will be as strong as a solid piece.
jesse_b
  • 674
