Trying to add a C wire for a new Nest thermostat. Currently only have a Red and White wire. There are no other terminals available for the C wire on the furnace transformer. Red go to one end of the transformer and the white one come from the other transformer terminal that went through the relay. Thanks in advance
Asked
Active
Viewed 82 times
If your furnace does not have the C wire from the control board, you may want to consider just buying a transformer and powering your Nest from it and using the Red & White to send the control signals:
https://sensi.emerson.com/en-us/support/adding-a-24-vac-external-transformer
Essentially all this talk about the C-wire is running a 24 VAC power line to the Nest Thermostat so it can charge the battery and keep running.
If your furnace control board doesn't have those lines, you can create external power to the Nest (using the external transfomer) and drive the control lines individually.
Leroy105
- 313
- 1
- 8
- 18
