I had 100 amp underground service to my old garage. In 2” conduit PVC SCH 40, 24” trench, code USE wire size, slip joints, etc While building the replacement garage, Contractor poured the new slab in the wrong spot & the supply conduit now exits the ground 18” away from the exterior wall Didn’t really want to dig it up and splice in an 18” section (or just leave some underground loose wire) cause I’m afraid of nicking the insulation on the wire when I cut the conduit
Are there any better/easier ways to get the supply conduit from the ground & through the exterior wall?
Wray
Pull the cable (USE-2 in conduit? - that was masochistic) back (or out, but back is adequate), cut the conduit, make it go where it should, send the bill to the contractor, pull the cable forward again. You do have to attach a pulling rope to the cable end and not cut that in the process, unless you do pull it all the way out.
Edit: following the last bit of comment (as of this edit) you could dig down to place a hand-hole over the conduit coming up 18" from the building, and (not strictly code compliant, but...) carefully cut the conduit away from the wire just above the bottom of the hand-hole (or more easily, just above where the bottom of the hand-hole will be, when you install it) and install a second, separate run of conduit the short distance from the hand-hole to the side of the building. So if you buy a 12" deep hand-hole, cut the conduit 9" below ground level, install the hand-hole flush with ground level, and either make waterproof splices (to new stranded wires) or pull the uncooperative USE cable the short distance to the building if there's adequate cable to do that. Submit the bill for the hand-hole and new conduit to your concrete contractor.
