I'm looking for a way to remediate the aluminum wiring in a home built in the 1970s. Currently, the whole house is wired with aluminum and the switches/outlets are original and not aluminum rated.
After looking around online, I've seen three popular ways of dealing with this situation (besides rewiring the house):
  1. Pigtail the fixtures/switches/receptacles with copper wire using AlumiConn connectors.
  2. Pigtail the fixtures/switches/receptacles with copper wire using aluminum-rated wire nuts (purple).
  3. Replace the existing switches and receptacles with aluminum-rated ones ("CO/ALR") and use solution 1 or 2 for everything that isn't a switch or a receptacle.
Everyone seems to have various opinions on which is the best way to do it. Most of the electricians I've talked to so far have claimed that #2 is the best way to do it, but without having a good reason why (other than "that's the way we typically do it").
Which is the best option, and why? Is it possible to mix those methods?
Machavity
  • 26,498
  • 44
  • 100
ivorysoap
  • 151
The most likely reason for using method #2 the rated wing nut is:
  • lower cost
  • time and speed
  • use less space
Con
  • limited capacity (can't join multiple wires)
  • nut can only be used once
  • the twist can weaken the alu wire and retwisting will most likely break the end of the wire off and shorten the wire.
Method 1 - using the alumiConn
  • only choice if the Alu wire is short
  • easy to make a tight connection
  • handle multiple size wire and multiple wires (buy the size and ports needed)
Con
  • Takes up a lot space (in a tight box, difficult to fit them in
  • expensive and for larger size wire - multiple ports - Really Expensive
Yes - you can mix the three methods to fix any of the outlets that do not have aluminum-rated receptacles.
It would unusual to have none rated alu outlets and switches in a house wired with ALU wire unless the owner/tenents did replacements with improper receptacles.
If you are not pigtailing copper wire, then you need to replace the existing switches and receptacles with aluminum-rated ones ("CO/ALR").
For the outlets and switches you have pigtailed copper wire, then regular copper-rated receptacles can be used.
As others have recommended, always use the screw terminals and not the jab in the back. Alu wire always have to screwed on.
Programmer66
  • 2,782
