Just moved to a 1985 built house in Ontario, Canada that has a Honeywell thermostat that I'm trying to replace with a Nest. I am unable to understand the labeling of the current thermostat as the wiring diagram is partially torn so I'm not sure how to connect the Nest's corresponding wires.
Old thermostat model is Honeywell T7512A - photo attached. New thermostat is a Nest - photo attached
Questions:
- How do I mix and match? I am unable to find this information in the thermostats manual. Are the torn labels B for Blue and Rh by any chance?
- In the bottom row, that yellow/golden connector is a conductor - is that what they call the common wire or a jumper wire? I don't think this has any use in the Nest, right?
- Nest says its not compatible with a 110v or 120v system, where can I check my units voltage? I saw a junction box in the furnace room with wire nuts that has 220v hand written. Is there any other clue to be sure?
EDIT:
I found where the cable is spliced under the flooring. Here is the sequence of colored wiring coming from the thermostat to the board:
- Red wire spliced and connected to new Red wire secured to the R slot.
- White wire spliced and connected to new Red wire secured to the W1 slot.
- Green wire spliced and connected to new Green wire secured to the G slot.
- Blue wire spliced and connected to new Black wire secured to the Y/Y2 slot.
Here is the furnace wiring diagram:
Here are the splices:
