I wanted to use a 4x6 for a beam for two swings, with eye bolts with washers through the whole beam vertically. However I do not have access to 4x6. I can buy two 2x6, but how would bolts work? Since bolts would be in between of two 2x6 I am thinking the holding capacity is not as high as through a 4x6 because of the gap between two boards.
Any thoughts on how to hang two swings on two sandwiched 2x6?
anm767
  • 197
Yes, you can, if you fasten them together well. The whole is greater than the sum of the parts, as they say, because stiffness and twist resistance are a matter of the cross-sectional aspect ratio. This would also result in a lamination, which is actually an improvement over a single timber because of the variation in grain and knots.
Use pairs of 2½" corrosion-resistant screws every 12-16", or use staggered, galvanized or stainless bolts at the same intervals.
