I have a standing-seam metal roof (without gutters), which pitches down over the front door. This causes a couple of issues:
  • It is awkward to go out the door when it is raining, as you need to walk through a sheet of water. Yes, you will be going out into the rain, so I wouldn't expect to stay completely dry, but walking through a waterfall isn't always fun.
  • It causes splashback when the rain hits the granite stoop in front of the door, causing lots of water to hit the door frame and siding around the door. This is causing water damage, and a good deal of this wood needs to be replaced. But before I do that, I want to solve the problem causing this.
I think a rain diverter might be a good solution here, so the rain goes down to the side of the door, and misses the granite stoop. However, the resources I've seen online only show installing a diverter on a shingled roof.
I live in an area that gets a good deal of snow in the winter, if that matters.
Can I install a diverter on a standing-seam metal roof? Is there a reason I shouldn't? Is this a job for a professional roofer, rather than a DIY homeowner?
pkaeding
  • 121
0 Answers0
