Is it silicone adhesive that kitchen and bathroom remodelers use to "glue" a porcelain sink to the underside of a granite countertop around the perimeter of the cutout? Something else?
P.S. I know there's also a kind of screw attachment; I'm interested in the chemical composition of the substance since I want to detach the sink from the countertop.
mr blint
  • 2,091
  • 57
Most likely it's silicone. You should be able to cut it with a razor/knife to free the sink and then scrape/peel it off completely once the sink is out of the way.
gnicko
  • 6,251
  • 42
You can get silicones that are also adhesives. Best of both worlds.
Just search "silicone adhesive".
A selection from a UK builders' merchant chain.
Tetsujin
  • 11,635
  • 40
Whatever it is it's softer than both granite and porcelain
Just use a wire to cut through it.
Jasen
  • 26,920
  • 46
