I have a Trane hot air furnace that has recently become temperamental with freezing rain or snow contaminating the air supply. Can humidity in the air supply interfere with its operation? In new England, we usually have very cold and dry weather, the only common element here seems to be the wetness.
The flash code is three rapid flashes. It is described by Trane's documentation as "Pressure switch problem — Blockage in vent, condensate drain plugged, etc."
I checked the air intake, and it was never blocked, from the outside anyway. Twice this season the furnace would not start until the bad weather stopped, then it resumed operation on its own.
I am thinking something is causing condensation to freeze in one of the two venting pipes. Perhaps getting an endoscope to look down the 10' of pipe...
Any suggestions and ideas welcome.
0xF2
  • 175
0 Answers0
