I have VERY hard water. I replace the lower element and suck out/flush the bottom of the tank at least twice a year. I have very low HOT water pressure. Cold pressure is fine. I took the hot water line loose and ran a wire inside the hot-water-out tube inside the tank. It appears to be clear. However, when I tried on the cold water inlet tube, the wire only went a short distance. Can the cold inlet tube be clogged/restricted? Is there a filter or coil that I am hitting? Suggestions/recommendations?
Asked
Active
Viewed 957 times
