Does a burnt out florescent light bulb use the same amount of energy as new florescent light bulb does
No, a burned out fluorescent tube doesn't use any power at all. It is an "arc light", and if the arc has not struck, then there is zero current.
Power is Watts = Volts x Amps. If Amps is 0, then Watts is 0.
If the filaments at the end are glowing (the pre-heaters) it's using a couple of watts at most.
There will be a few watts of load in the ballast, depending on the technology of ballast (a lot more for an old transformer-based "magnetic ballast", very little for a modern electronic ballast).
- 313,471
- 28
- 298
- 772
It's more about the ballast than the lamp. Most modern ballasts are electronic which can sense how much power is demanded and only provide that amount to flow. Old-style autotransformer type ballasts, because of their design, let current flow whether there is a lamp in the fixture or not.
- 87,685
- 36
- 144
- 243
- 13,677
- 12
- 32
