My motorhome came with a 15 amp transfer switch, i have 30 amp service, can i replace with a 30 amp transfer switch, as cannot find a 15 amp switch on market?
Asked
Active
Viewed 112 times
Normally there is no problem going with a higher rated transfer switch than the one supplied. Depending on how the connections are made, you might have to change some of the spade, eye connectors. You might also have to change the the mounting holes, mounting brackets but those are all fairly easy changes to make.
JACK
- 89,902
- 21
- 80
- 214
